Megan Header Install
Hey guys i just received my megan header. I want to do the install myself to save some extra cash. Are there any DIY write ups ive searched but didnt see anything.
There is a write up in the DIY.
You need to jack your car REALLY high on the front or use a lift. Remove heat shield. Unplug o2 harness, loosen o2, remove stock header heat shields, drop stock header by slightly turning and lowering. Put in new one the same way. Use new gaskets if possible. Torque bolts in correct pattern + use torque wrench. Reset ECU.
MattZ28
11-21-2010 04:13 PM
