Mechanic put 10w30 into transmission
Old 11-14-2012, 08:40 AM
  #21
4forall's Avatar
I use my aunt bertha's gravy in my diff!
Anywho glad he is taking the time to do the work correctly. Kudos to that.
Old 11-14-2012, 08:45 AM
  #22
dsthez's Avatar
Maybe some copper plugs to boot
Old 11-14-2012, 08:57 AM
  #23
2K_S2000's Avatar
The fact you had to ask and was advised differently doesn't bode well for confidence. The invoice should detail everything correctly and you should've been advised when you picked up your car.
Take it easy while that 10W30 is in your transmission.
As the Honda slogan goes "Don't open your hood to strangers".
Old 11-14-2012, 09:22 AM
  #24
raymo19's Avatar
The 10W-30 in the tranny won't hurt a thing. The wrong fluid in the diff, however, is a very serious problem. You need to confirm that it is the correct spec.
Old 11-14-2012, 01:32 PM
  #25
dwight's Avatar
Originally Posted by JackS
Originally Posted by dwight' timestamp='1352873148' post='22149758
It's not a big deal as long as it's fixed, but you should start looking for a new mechanic.
I think that may be a little harsh.The best choice was probably unavailabe so in the meantime 10/30 it is.
OP said he req'd Honda MTF. The guy did something else instead. If he didn't have the MTF on hand he should have held off on the work and notified the customer, not wing it.
Old 11-14-2012, 01:34 PM
  #26
dwight's Avatar
Since there are two of these threads, can we lock one of them?
Old 11-14-2012, 02:01 PM
  #27
Billman250's Avatar
Received 1,403 Likes on 840 Posts
threads merged together
Old 11-14-2012, 02:03 PM
  #28
Billman250's Avatar
10w30 used long term in the transmission will damage the syncro teeth, 100% guaranteed.
Xeon
10-14-2016 02:01 PM
NobleAccord
09-18-2016 06:31 AM
luv my ford
02-10-2012 08:07 PM
phonedrn8
11-18-2010 01:27 PM
Hoobahole
01-23-2005 09:41 AM
Quick Reply: Mechanic put 10w30 into transmission
