Master and slave out?
Clutch fluid running out quick.. Have to keep an eye on it..Maybe master is out or slave?? Any suggestions??
Sent from my iPhone using Tapatalk
both of mine have leaked. ive only replaced the slave. if you look under the dash behind the clutch pedal you should see a rod, mine had fluid coming out of that. so i just cleaned it up, and topped it off
