Master cylinder replacement
Originally posted by billman250
Dot3 and Dot4 are compatible in "3&4" systems. You Should NEVER add 3 to a 4 only system. The clutch system and the brake system, on the S, are designed for 3 or 4. Go with 4 for a higher standard of brake fluid.
I would suggest reading this.
http://www.stoptech.com/whitepapers/brakefluid1a.htm
Originally Posted by gabster,Oct 18 2010, 01:52 PM
Back from the dead, mine CMC is leaking, advice on replacement parts, should i get it new or would one with about 16k miles be good enough?
When in doubt with a brake or brake fluid reliant part - spend the extra cash and buy a new part.
Brake fluid absorbs water, and even if the part has sitting on a shelf in a climate controlled room - that part has a shelf life once brake fluid has touched its internals.
BTW - THANK YOU for using the search and doing the research - an example for all.
^^ Good advice.
I change/bleed my fluid ~yearly (if I'm in country) - and have never experienced a leak. Original 2003 equipment with ATE DOT 4 fluid.
Unrelated:
Billman: your valve adjustment is still spot on since you swapped out the intake retainers in 2008 - I checked the lash again last weekend... no adjustments needed - thanks again.
You were also right about the brakes (Brakeman calipers) as well - there were frozen pistons in both calipers. I had them rebuilt and the brakes are like new. Storage, no matter how well climate controlled still allows moisture over time. Replaced the brake master cylinder as well - seals were bad. The car was stored for 3 years while I was overseas in the Middle East (and associated training)
Unrelated:
Originally Posted by Billman250,Oct 18 2010, 07:55 PM
95% of s2k CMCs leak.
Keep your fluid clean and the leak will stop. no need to replace it.
Billman, would you still recommend Honda DOT 4 brake fluid from motorcycles for the CMC? or other kind of fluid?
Thanks!
