Master cyl replace or fix?
Old 03-05-2010, 05:23 AM
  #21
Billman250's Avatar
Received 1,403 Likes on 840 Posts
The fluid gets dirty fast from the amount of travel and frequency that the clutch pedal is pressed. It is many times more than the brake master.
Change it ever 5k miles, it should take you 3-5 minutes. you don't even need to bleed it or flush it. Empty it with a turkey baster, clean it out spotless with paper towls, and refill it.
Mine leaked bad when I first noticed it, it has since stopped. Just like a few other hundred s2ks have stopped.
I also find that ATE super blue will stay cleaner longer. If you switch to super blue, you will then need to do a flush.
mambo
03-21-2014 07:18 PM
civdaddy
09-19-2013 03:02 PM
smad
07-16-2013 02:31 PM
refect
02-27-2010 06:39 PM
tampaSuzuka
02-09-2010 04:36 PM
Quick Reply: Master cyl replace or fix?
