Marking differential fill bolt for tightening will not work
As you probably already know, it is not possible to get a torque wrench in a position which will enable you to use it to torque the differential fill bolt to the proper specification which I believe is 33ft-lbs. I thought about how I might get as close as possible to the factory specified torque by using another method to guesstimate. I decided that I would mark a continuous line from the fill bolt on to the housing around the fill bolt. When I was done filling my differential, I would then be able to simply tighten the fill bolt until the line lined up again. Upon looking at the differential fill bolt I found that there was already a yellow line that had been marked on the fill bolt and it happend to go on the housing as well, so I decided to use it instead. Here is a picture before I loosened the fill bolt:
Well, I guess that it was a good idea to try, but things did not pan out. When I went to tighten the fill bolt, I went well past what my arm tells me is 33ft-lbs and the fill bolt still had a way to go in order to get back around to where it was. Here is an after picture:
My guesses as to why my method didn't work are that the new washer was a different thickness or the fill bolt was over-tightened at the factory. The bottom line is that this method won't work, but I'm open to new suggestions.
Why do you care? Snugging this bolt by hand with an simple wrench is all that is needed. It is just a big plug with no critical function and no stress.. just give the wrench a shove after it is already screwed in and go on to other things.
Originally posted by cdelena
Why do you care?
Why do you care?
It has to do with what position the line was in when you started tightening it. So it may not work.
Mine lined up when I changed the fluid this weekend, but I think it was just a coincidence.
