Map Sensor question
Map Sensor question
I bought a turbo kit from my boy, and said he needs stock map sensor w harness and clip. I know where all that is, but can anyone clarify what parts it is? Is it the plastic denso map sensor that is bolted on intake manifold... pics please?
I'm guessing you bought a turbo kit and it comes with an upgraded MAP sensor.
The person you bought it from needs your OEM MAP sensor.
Is that right?
If so, he needs the Denso MAP Sensor you referred to, the connector for the harness and a few inches of wire. When you fit the aftermarket MAP you will have to cut the wire anyway.
Is that right?
ScienceofSpeed
01-24-2011 01:17 PM
