View Poll Results: MAP Sensor Problems
Yes - my dealer understands me and replaced under warranty
0%
Voters: 14. You may not vote on this poll
MAP Sensor Problems
MAP Sensor Problems
Can someone post some photos showing the position of the MAP sensor and also tell me how to reste the ECU ?? and also list the tools necessary to remove/fit ?
Resetting the ECU can be done either by unplugging the battery for a few seconds (you will need your radio code also) or if you look on the FAQ's it tells you which fuse to pull.
See attached photo for location of map sensor
Hope that helps
Hope that helps
