MAP sensor problem showing up at 35k miles? Plus some interesting data
#73
Well, Honda sent out an engineer and 'fixed' the problem (again). This time they had the car for 4 days, replaced the ECM, harness, all coils & plugs, all injectors, and MAP sensor. If that doesn't do the job, THEN WHAT?!?!?
I hope this is the last time.
FYI; other than a bad diff, this is the only problem I have had with the car.
#74
my car also experienced the boggy feeling and the car will not get out of its own way. i recently got a PLX wideband 02 and when this situation goes on the air/fuel readings are all F@#%ed up jumping to extremely lean and rich making the car very difficult to drive. i hit the map sensor and it didn't do jack. i reset my ECU and my car runs great. this has happened to me many times before but never reset the ECU, i would just put it away and the next day start it up and be fine this is very annoying when this happens and wish there is a permeant fix on this
MAtt
MAtt
#78
Just to add a lil here...a NEW, UPDATED MAP sensor is supposed to come out for our car, this month(oct) or next month. Lemme search for the info.....
