Map Light will not work
So anyone got a fix or a solution to this?
Mine worked fine, but when I took the assembly off and replaced the Top Strikers for the Convertible top, the Left and Right ON/OFF switches dont work...WTF
I remember seeing a thread about cleaning the contacts or whatever on the bottom of the 3 way switch. Overtime they get corroded. My switch is picky, I haven't taken the time to take the assembly apart and clean it yet. When it flickers or stops working I have to move the switch less than 1mm to the left or right and it will usually work again.
Yup, my contacts were green-ish, cleaned them up and all is good, must have done it because of the switch being in center position most of its life and when i moved the switch, the contacts got gunked up...
