Man i need some help!
Starting up my car and sometimes ! it shakes and drops way low below 1 rpm, like it wants to stall. when i leave i can past 7k rpm to shift at 9 but if i drive past 10 min or so i cant past 7 k it just stopps not like a rev limiter stop but like a little pitch. I check out some searches and changing spark plugs might do the trick for the shaking. but couldnt find out y the only 7 k rpm =*(., need some help fellas alot will be appreciated
Are you sure your sister hasn't done something to your car again? (Couldn't help myself.)
Have a look at this. It may have something to do with your situation:
https://www.s2ki.com/forums/index.php?showtopic=253242
Try the MAP whack and ECU reset. If this fixes it, then take the above thread more seriously.
Also, your car may simply be having a brain fart due to a sudden climatic change in your area lately (air temp, humidity, air pressure). Sometimes this causes the ECU to have a hard time learning to adjust. It can take a few days to learn.
Originally Posted by SIIK2NR,Jun 13 2005, 11:50 AM
Question.....Could a loose throttle cable effect idle and rmp range?
It sounds like for whatever reason you car is going into "safe mode". Most common cause is a cold motor. Most beleive "three bars" is good to go. Actually the V-Tec solenoid is oil pressure allowed, which occurs just above three bars of water temp. If the car is genuinely warmed up....You need to have the OBD-II codes pulled for evaluation. The ECU can recognize certain conditions and will prevent the car going into V-TEC (~6,400 RPM). While a CEL may not be illumintated a short term fault is probably being stored.
Utah
Utah
