MAJOR HELP PLEASE!
#31
Don't even hit the start button until a complete properly assembled tct is in place.
This is your chance to NOT destroy your engine, you've been more than warned and helped.
#33
Ok guys I decided to do it myself. So I took off the cover for the chain and found the rest of the TCT parts in there. Going to retract the tct and put it back. Question is. I started the motor twice when this happened for less than 1 min. Will my timing be off?
#35
Check by lining up the cam marks and the yellow notch on the crank pulley.
#38
Originally Posted by Kengthao91' timestamp='1424935421' post='23519773
Yeah nothing should have fallen in. Im not missing anything. Unless when I took off the vtec solenoid there suppose to be a spring and metal peice that slide out with it right? I just got the cover and the spring off. Or I may be wrong. I might take it to Honda to take a look
If you removed the TCT its likely that you didn't get it back together and installed correctly and the noise you are hearing is the timing chain rotating with no tension on it. Don't start the engine until you figure out what you actually removed.
#40
Install the tct and crank my car, started for less than 2 sec then it die and now I can't start it up agian. Everything was install correctly. I don't know what's the problem now.
