Maintenance Schedule in plain english
Old 03-16-2013 | 02:44 AM
2009 s2k's Avatar
Default Maintenance Schedule in plain english
I've searched my owners manual and these message boards and can't find a straight answer on maintenance intervals. Maybe i'm searching the wrong terms, but this is driving me nuts!
My owners manual talks about the "maintenance minder", which is essentially telling me that this feature will tell me when I need to do all maintenance.
I'm looking for the intervals for all fluid changes under NORMAL driving conditions. i'm a little puzzled....this manual seriously doesn't state these intervals...it provides the symbols for main and sub maintenance items, but not the milage intervals for normal driving conditions.
Can someone please point me in the right direction?
Thanks!
DAVID304 (09-19-2022)
Old 03-16-2013 | 03:52 AM
kryptonite's Avatar
Member
Spotter
3,750 mi/6,000 km
Replace engine oil and filter.
7,500 mi/12,000 km
Inspect front and rear brakes.
Check tire inflation and condition.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
11,250 mi/18,000 km
15,000 mi/24,000 km/1 yr
Replace air cleaner element.
Check parking brake adjustment.
Replace rear differential fluid.
Lubricate all hinges, locks, and latches with multi-purpose grease.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
#Inspect exhaust system.
#Inspect fuel lines and connections.
Check all lights.
Inspect the underbody.
# = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual.
18,750 mi/30,000 km
22,500 mi/36,000 km
26,250 mi/42,000 km
30,000 mi/48,000 km/2 yrs
Check all lights.
Inspect drive belt.
Replace dust and pollen filter*.
* = See dust and pollen filter on page 187 of your owner's manual for replacement information under special driving conditions.
33,750 mi/54,000 km
37,500 mi/60,000 km
41,250 mi/66,000 km
3 years
Replace brake fluid (independent of mileage).
45,000 mi/72,000 km/3 yrs
Check all lights.
48,750 mi/78,000 km
52,500 mi/84,000 km
56,250 mi/90,000 km
60,000 mi/96,000 km/4 yrs
Check all lights.
Inspect drive belt.
Replace transmission fluid.
63,750 mi/102,000 km
67,500 mi/108,000 km
71,250 mi/114,000 km
75,00 mi/120,000 km/5 yrs
Check all lights.
78,750 mi/126,000 km
82,500 mi/132,000 km
86,250 mi/138,000 km
6 years
90,000 mi/144,000 km/6 yrs
Check all lights.
Inspect drive belt.
93,750 mi/150,000 km
97,500 mi/156,000 km
101,250 mi/162,000 km
105,000 mi/168,000 km/7 yrs
Replace spark plugs.
Inspect valve clearance.
Check idle speed.
Check all lights.
108,750 mi/174,000 km
112,500 mi/180,000 km
116,250 mi/186,000 km
120,000 mi/192,000 km/8 yrs
Check all lights.
Inspect drive belt.
9 years
120,000 mi/192,000 km/10 yrs
Replace engine coolant, then replace every 60,000 mi/96,000 km/5 yrs.
Maintenance Schedule for normal conditions:
7,500 mi/12,000 km
Replace engine oil.
Replace engine oil.
Replace engine oil filter.
Check all fluid levels, condition of fluids and check for leaks.
22,500 mi/36,000 km
Replace engine oil.
Replace engine oil.
Replace dust and pollen filter.
Inspect drive belt.
37,500 mi/60,000 km
Replace engine oil.
3 years
Replace engine oil.
52,500 mi/84,000 km
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace engine oil.
75,000 mi/120,000 km/5 yrs
Replace engine oil.
Replace engine oil.
6 years
Replace engine oil.
Inspect drive belt.
Replace engine oil.
Check idle speed.
Replace engine oil.
Replace engine oil.
Replace engine oil.
Inspect drive belt.
9 years
The following 5 users liked this post by kryptonite:
CMK (06-29-2017), DOXI (04-27-2022), S2k_OMAR (03-20-2024), slivered (07-03-2019), Vail_Colo (01-24-2021)
Old 03-16-2013 | 06:08 AM
takeshi's Avatar
If you create an account on OwnerLink you can also pull this info.
Old 03-16-2013 | 09:52 AM
2009 s2k's Avatar
Thanks for sharing the intevals.
I did create the account on owenrs link, and it doesn't provide the intervals, just the sub and main maintenance minder codes.
Old 08-05-2015 | 06:30 PM
encoreman's Avatar
Great list! I'm doing most of the things on the list myself. Planning on going to Honda to get valve timing checked. 125000 miles...
Old 08-06-2015 | 04:51 AM
robertcope's Avatar
My owners manual (2001) has this all nicely laid out in charts and text. Did later manuals get rid of this?
robert
Old 08-06-2015 | 05:35 AM
Chuck S's Avatar
Valve clearance checking/adjustments is one of the simplest DIY services you can do on your own car. Need a cold engine so you'll have to drop your car at the dealer the night before. Ya need replacement gaskets and a $10 adjustment tool (to avoid juggling a wrench and screwdriver) and an $8 set of bent feeler gauges. Plan on an hour, two at the most. Details are in the maintenance section here. Videos abound. It's more tedious than difficult. Adjust to the loose end of the range as they tighten in service. Exhaust is the critical valve. While you're in there do a compression check (need a buddy) and, since the plugs are out, spend $40 for new ones. Put in the new spark plug and cover gaskets and tighten to torque spec. Done and satisfying. Much cleaner process than an oil change.
Replaced your TCT? Good preventive maintenance. Good time to do it while you're under the hood/bonnet. Billman unit installs in 10 minutes. I didn't bother changing into work clothes to do mine earlier this summer it's so simple. 10mm ratchet spanner (not socket wrench).
Scheduled maintenance went away in 2006 manual and was replaced by computerized maintenance in the Maintenance Minder built into the instrument cluster. This system bases preventive maintenance services by miles, engine load, etc.
I downloaded the 2005 Owners Manual, the last one with the maintenance schedule, just for verification. I doubt my S2000 will trigger the Maintenance Minder as I do an annual oil/filter change and my annual mileage is less than the interval specified. I currently show 70% oil life remaining from an earlier oil/filter change and reset of the MM. I did the transmission a year ago and will again on the next oil change. Differential probably next year too although it's not called for so soon. Only uses a quart of oil so why not?
-- Chuck
Old 08-06-2015 | 08:32 AM
Slowcrash_101's Avatar
I just change the oil when the maintenance light comes on ~5,000 miles, even though I run Castrol edge 10w-30 gold bottle. All the other maintenance I do yearly or bi-yearly. Diff, pcv valve, brake fluid, clutch fluid, grease all latches and hinges, and clean the underside of the car is all done yearly. Tranny fluid, drive belt, A/C drier replacement, brake pads and rotors, I change those out every other year. Coolant once every 3 years, and tires whenever the rears show no inside tread. I also check hoses, and for oil leaks, and instantly replace anything leaking(O-rings, vtec solenoid) or any hose that looks suspect. When I did my clutch I also changed the rear main seal, I know I probably didn't need to, but it was cracking and I hate taking out the transmission. You can also save a lot on maintenance and part replacement by buying high quality parts. OEM is extremely good, there's not a lot that's better than OEM. Things like bearings for instance SKF > NSK as far as bearing quality goes. Everything else though, you'd be hard pressed to find something better than OEM, even the bolts are extremely high quality, except for some questionable fasteners like the driveshaft bolts.
I like to change the valve cover gasket every 3 years. The O2 sensors(at least the primary) should really be replaced after 100,000k, they start to get lazy around then. I do spark plugs along with valve adjustment whenever I replace the valve cover gasket.
Old 08-06-2015 | 09:01 AM
Car Analogy's Avatar
I would rethink that. How much experience does the dealer tech have adjusting valves? The only car in the lineup that needs this service is the S, so not much. Add that dealer techs are always rushed, and this is the sort of service you can't even tell if they did it (unless valves are noisy), and they call it the stealership for a reason, well, yoy are asking to get fleeced.
Find a local shop that has experience with adjusting valve cleances, or better yet S2K experience.
Old 10-21-2016 | 04:57 AM
CJ2006's Avatar
I know this is an old thread, but I wanted to post a relevant update for everyone.
The link has changed, and there is no longer a need to login, just select year and model. It's now: http://owners.honda.com/service-maintenance/minder
Here's the maintenance schedule for a MY06 S, for example: http://owners.honda.com/service-maintenance/minder?year=2006&model=S2000#mid^AP2146ENW
Both Normal and Severe are view-able, and you can expand all and then print easily for reference.
naiewt
05-14-2008 07:22 AM
imdarkrider
02-24-2007 09:08 AM
FooF
09-02-2004 12:02 PM
aceprince
11-21-2003 02:04 PM
jrfblueeyes
10-15-2003 07:39 AM
