"Maintenance Required" Light flashing
Nope, its does that every 6 to 7k miles reminding you to change your oil. Here is how to reset it.
Put the key in the ignition and in the "OFF/LOCKED" Position.
•- Hold the Trip/Reset Button on the right bottom corner of your gauge cluster
•- Now - Turn key to the "ON" Position while continuing to hold the Trip/Reset Button till the light goes off.
•***If the light is still at the "blinking" stage and not yet solid - continue to Hold the button for around 25-30 seconds just to make sure it resets
Gotcha. Thank you sir.
I didnt think that was the problem since I took it to the dealer less than 500 miles ago for an oil change. Damn stealership.
hyperpm
07-17-2002 09:50 AM
