Maintenance required light
Ok, Ive had my car 8 years and ive reset this light many times over the 107k miles i have driven it. Over the weekend the maintenance required light on the dash lit up. So nbd i said as soon as i got home i went and did the standard reset routine. Key in off hold trip button turn ignition to on wait for light to go out. Well all it does is blink off for half a second and than stays lit?
Any ideas?
To clarify the standard routine to reset is not clearing it.
Thanks
Any ideas?
Thanks
Thanks but that didnt work
Ok here is what has been done
Trip button help while cycling key didnt work
Trip and select button held while cycling key didnt work
Sel button held while cycling key didnt work
Im at a loss
Im at a loss
^ either that or ill take the cluster off and pull the light
Actually i think its an electrical glitch itll prob reset when i pull the posi terminal off the battery for a while...
Ok update, after really getting frustrated with it i took a sledgehammer to the dash and obliterated it, only thing is now the speedo does not work
J/K J/K
I sat there and held the trip button for 3 minutes and finally it reset end of story.
J/K J/K
Vash
10-14-2003 12:13 PM
