Maintenance Items
Maintenance Items
Hello all. I just got my S2000 recently it is a 2002 with 51,xxx miles and I had a plan for some maintenance give me some input.
1.Cabin Filter
2.Air Filter OEM
3. Spark Plugs (ngk or denso)
4.Diff fluid
5.Trans Fluid
6.Oil change Amsoil (10w30 or 5w30)
Anything else?
1.Cabin Filter
2.Air Filter OEM
4.Diff fluid
5.Trans Fluid
Anything else?
https://www.s2ki.com/forums/index.php?showtopic=153537
45,000 mi/72,000 km/3 yrs
Replace engine oil.
Check tire inflation and condition.
Inspect front and rear brakes.
Replace engine oil filter.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids and check for leaks.
#Inspect exhaust system.
#Inspect fuel lines and connections.
# = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual.
52,500 mi/84,000 km
Replace engine oil.
Replace engine oil.
52,500 mi/84,000 km
Replace engine oil.
don't forget the pcv valve, one of the cheapest parts but one of the most important as well.
Get some Shen Itsu grease from Honda and lube the convertible seals and weatherstripping, good maintenance item.
Use Raggtop cleaner and preservative on the convertible roof.
Lubricate the slave cylinder and shifter if you can. Swap out the brake fluid and clutch fluid too. Consider a valve adjustment in the future.
I just bought my car with 55,000 miles, my initial list was as long as yours but has grown to about five times that length, one thing leads to another once you start doing searches on this forum. Tons of information available on this site to help you with your car.
