Maintanence Intervaels
What kind of maintanence is required for the honda s2000. I say this cause my mant req light is on at 19700 miles and I dont want to disregard it. So what kind of up keep should be preformed and at what mileage.
For this MIL
Oil & Filter
Front and rear brake inspection
-Pads and discs for wear ,thickness and cracks
-Calipers for damage leaks and tightness of mounting bolts
Tire inflation & condition
Tie rod ends, steering gearbox and boots
-Check rack grease and steering linkage
-Check boots for damage and leaking grease
Suspension comps.
-bolts tight
-ball joint boots
Driveshaft boots
-wear
When done to reset Maintenance indicator light (MIL)
-Push and hold trip button
-Turn ignition switch on
-Hold the trip button for 10+ seconds
Utah
Oil & Filter
Suspension comps.
-bolts tight
-ball joint boots
Driveshaft boots
-wear
Utah
The_Chinadian
01-16-2007 06:45 PM
