maintanance required
The manual isn't very clear on this one.
I believe you need to turn the key to the ACC(I) position, press the reset button and hold it whilst you turn the key to the on(II) position. Continue to hold the button until the light has turned off.
I may be wrong, but I remember it being this way.
Here you go:
To reset the MAINTENANCE REQUIRED light (As indicated by the light that says, "MAINT REQU'D"):
- Have key inserted in ignition but in the OFF or LOCKED position.
- Push and hold the trip reset button on the right bottom corner of your gauge clutster.
- Turn key to full ON position and continue holding the button till the light goes off.
-(This part has been added for those who are impatient or who have the light only at the "blinking" stage and not yet solid.) KEEP HOLDING THE BUTTON FOR ABOUT 30 SECONDS TO BE SURE OF A POSITIVE RESET. Or maybe just be patient and wait till the light is on all the time before doing this.
- (Some manuals may be a bit off in that they do not tell you to turn the key to the ON position.)
Originally Posted by an2ny,Dec 14 2006, 07:11 AM
Here you go:
Vash
10-14-2003 12:13 PM
