Maint Req'D Light at 24.6K miles
It comes on a certain number of miles after the last reset. It does not know what service is required, just that the timer has expired.
Reset the light by holding the trip button down while turning the ignition on. Hold the trip button until the light goes out (~10 seconds or so)
Was the light on when you did the oil change a thousand miles ago?
On the MY02, the light is just a milage counter...it doesn't actually know when you change the oil unless you reset it. You should reset it each time you change the oil even if it isn't on.
wow i appreciate the inputs guys. I'll reset it when I get home from class tonight. I actually just bought the car and the lady was nice enough to change the oil for me at the dealer. but shouldnt they reset it?
You might want to check and see if your car came with an Owner's Manual. If it did... read it. Also, the FAQ at the top of this forum has lots of good info for a new owner. I recommend also referencing that when you have a question.
Originally Posted by Mr. Eryozgatliyan,Sep 2 2008, 01:26 PM
I dont think
https://www.s2ki.com/forums/index.php?act=S...0#entry12038951
