Magnetic oil drain plugs
http://www.magneticdrainplugs.com/metric.htm
Good source of all sorts of specialty plugs for all cars.
The Hondra drain plug is 1085M. Same zinc dichromate finish as OEM.
Magnetic drain plugs are good for diagnosing possible engine trouble.
They also sell the gaskets I like - a combination rubber inner seal with an aluminum outer:
http://www.magneticdrainplugs.com/gaskets.htm
Part.no 2602 $.49 each
It's good to put the magnetic oil drain plug on for "extra" protection. I've been using it on my 91 Civic and I do remove particles on the plug at every oil change. Thanks for the info, now I can order one for my s2.
I would like to see some company come up with a magnet that could mount to say the valve cover and be cleaned from time to time.
Notice I did not say for protection - the pieces you usually accumulate are so tiny that they are inconsequential - the real advantage of a drain plug magnet is to look for larger pieces, which are often precursors of major engine problems; that is, a "tattletale" device.
Glad you liked it. Price is right, and those gaskets are the bomb.
[QUOTE]Originally posted by Road Rage
I'd like to see a one that uses a better magnet (like a neodymium one). Those those are so much stronger than the cheap ceramic magnets I always see on drain plugs.
