M3 differential fluid
Old 07-24-2021, 10:59 AM
Slowcrash_101's Avatar
Originally Posted by Chuck S
Got me (again).
-- Chuck
GL5 specifies EP additives where GL4 aka transmission fluid does not.
https://www.widman.biz/uploads/Transaxle_oil.pdf
Good read on the subject.
TL;DR synchromesh fluid and 75w80 gl4 oils are ok to use in the transmission. GL5 85w90 up to 75w140 is ok on the diff. The two gears being steel benefit greatly from EP additives like MoS2 WF2 etc.
Do not use GL5 fluid in the transmission and do not use GL4 fluid in the diff.
Transmission uses GL4 diff uses GL5.
GL = gear lubricant, the number specifies the amount of phosphorus/Sulphur ep.
pers785
12-08-2015 04:26 PM
2005GPW
South Florida
26
12-09-2005 07:06 PM
s2kjones
08-12-2004 12:16 PM
blue2k2s2k
06-24-2003 06:21 AM
99civicboy
04-11-2003 10:13 AM
Quick Reply: M3 differential fluid
