lug nuts
Old 03-09-2008, 01:48 AM
mikegarrison's Avatar
There are a number of processes that can make nuts hard to remove or install. Corrosion is usually the main one, but any wear can cause the threads to get rough, which will increase the friction. Just consider how a knife dulls with use. The same sort of thing will give threads more and more friction.
A little anti-seize on the threads is fine. It makes for a more repeatable torque wrench number and helps prevent against corrosion. You can also chase the threads with a tap or a die.
Ideally, you would rather just replace these things every so often, but unfortunately it is a major PITA to replace the studs on an S2000. Replacing the nuts is much easier, but may not solve the problem.
Old 03-09-2008, 05:15 AM
oOweEe's Avatar
i recently replaced my wheels and didnt have a torque wrench or anything, i just used the jack in the trunk... now i know this is really hard to say... but whats the right amount of "tightness" when hand tightening it?
just to be sure, i gave each a little kick to tighten them a bit more.
thanks!
Old 03-09-2008, 05:29 AM
80 ft-lb.
If you don't know what 80 ft-lb feels like -- well that should be a hint about what your next step should be.
Old 03-09-2008, 03:26 PM
KnowledgeIsPower's Avatar
go get a torque wrench or this could be you
http://youtube.com/watch?v=jv4m41viy4I
Rdragon
05-27-2010 02:31 PM
FASTSIIK
11-21-2008 12:44 PM
S2Kmonkee
11-04-2008 01:15 PM
just2fast4u
01-18-2007 08:45 AM
Quick Reply: lug nuts
