LSD question
Old 05-21-2007, 04:20 PM
RED MX5's Avatar
[QUOTE=vspc2nr,May 21 2007, 06:44 PM]nope, lol
ok, last is your talking about KAZZ diff's.
Old 05-21-2007, 07:25 PM
vspc2nr's Avatar
hmm, come to think of it she just started it so it was shut down for atleast 2hrs. Whats the qualifications?? i like it sidewayz, what can i say.
Old 05-21-2007, 07:50 PM
RED MX5's Avatar
[QUOTE=vspc2nr,May 21 2007, 10:25 PM]hmm, come to think of it she just started it so it was shut down for atleast 2hrs.
Old 05-21-2007, 10:57 PM
vspc2nr's Avatar
lol dont worry, it was either my(or our)S or a FC. Im in Wa. state. tnks red, your very helpful.
Old 05-21-2007, 11:52 PM
SpitfireS's Avatar
RED MX5 Posted on May 22 2007, 12:30 AM
Anyway, if it's the clutch assist in the Torsen you're hearing I'll bet it goes away with a fresh load of oil.
What is the "clutch assist" you're talking about?
IMO there is no such thing in "our" Torsen T-2, there are "thrust washers" between the side gears, but they are not made of friction clutch type material but hardened steel IIRC.
If not, a touch of friction modifier in the diff might smooth out the clutch action and stop the noise.
IMO the Torsen does not require any friction modifier, just good GL-5 oil.
Oil that can't handle the power will - in time - make the Torsen behave strangely, especially around tight corners, making the inner wheel turn as fast as the outer wheel (it won't allow differentiation) and pushes the car out of the corner.
I've experienced that first hand.
Fresh SAE 90 GL-5 oil "fixed" it instantly.
http://www.torsen.com/index.htm
Old 05-22-2007, 10:36 AM
vspc2nr's Avatar
http://www.torsen.com/files/Torsen%20T-2%2...cal%20Sheet.pdf
wow....
Old 05-22-2007, 11:52 AM
RED MX5's Avatar
SpitfireS, I could swear that I read about the clutch assist on the torsen Web site, and I even thought it was in the very PDF file you linked, but I have looked at all their stuff now and I either dreamed it or read it somewhere else. I'm pretty sure I wasn't a dream, but until I can figure out where the heck I read it and post a link that's what it looks like.
I read somewhere that the S2000 differential has small clutches to speed up it's action. Seems like there was a picture too. For some reason I took the source to be reliable, and I've never actually looked at the breakdown of our diff in the shop manual to see if there was really any difference from a regular Torsen. Right now my manual is at the shop and I can't look, but if you say we have a standard T2 with no clutches, I consider that to be a reliable enough source. I'll just ask you if you're *sure* our LSD isn't a little different from the standard T2? If you're sure, that's good enough for me.
I do know that unless there are some kind of clutches in the LSD, friction modifiers won't help, but I didn't know a Torsen could get noisy with older oil. The reason I've never seen it is no doubt because I change fluids at frequent intervals. When the oil gets old in the Torsen, does it actually "click" like the OP described? His discription sounds exactly like a description of a cold clutch-type LSD (or one full of well used lube) on a smaller scale.
LOL, I could have sworn that I read about the clutches in the same sheet Vspc2nr linked above.
Old 05-22-2007, 12:48 PM
RED MX5's Avatar
OK, I think I figured this out. Apparently at some point (probably while looking at alternate LSD's for the S2000) I got the impression that the S2000's had the T2-R. I'm thinking that I must have read somewhere that the S2000 had the T2-R, but it doesn't really matter where I got my mistaken impressions. Thanks for clearing it up SpitfireS.
The PDF file describing the T2-R is here. For those that don't car to read the whole thing ...
[QUOTE]The TORSEN T2-R takes the T-2's performance to the next level.
glagola1
05-11-2012 08:02 PM
pd0019
03-03-2010 11:21 PM
87yj
03-14-2004 07:28 PM
Uncle Fester
09-09-2002 08:37 AM
MHK S2000
11-16-2000 10:13 AM
Quick Reply: LSD question
