LSD
Originally Posted by run115,Dec 16 2007, 08:42 AM
I always thought that the S2000 comes with a factory fitted LSD as standard, am I right or wrong?
This is a stock rear that is open, it shows the gears, LSD, and bearing cap.
Kitty says, Hope the pics help
Thanks for the help, so why would I need to change the LSD for a KAAZ unit for instance, are clutch types any better than torque sensing ones?
you will be fine with a stock setup. You start messing with wider rims and more track/performance items and you will start adding stress points on the rear end.
