LSD?
Old 05-25-2006, 06:59 AM
Wisconsin S2k's Avatar
check your tire pressure. seriously. 99% of the time that's the problem.
also, we don't have a "clutch" system LSD. our LSD is gear based. it's either working or it's not. there's no in between. if your LSD was bad, you'd know it, because you'd barely be able to drive the car, if at all.
Old 05-25-2006, 08:45 AM
sahtt's Avatar
No non LSD'd car is going to go 'sideways' when it loses traction due to power. Want an easy test? Go look at your tire marks.
Your LSD would be clunking and banging if it was 'out'.
Old 05-25-2006, 10:23 AM
BlownAP's Avatar
ok thanks for all the input guys, ill be sure to check the tire pressure today,
but 3 techs looked at the car at honda cars of Corona, and they cannot figure out whats wrong with it, so thats why the factory rep has to come out. so if it is just the tire pressure, well they need to hire new techs.....
about the tires, all 4 tires are brand new.
thanks again for all the imput and enlightening me about the LSD
on a side note i might have forgot to mention, while i drive fast and upshift fairly quickly in between shifts the car seems to get VERY unstable and on the 1-2 shift, the back end wants to step out.......
Old 05-25-2006, 10:27 AM
BlownAP's Avatar
Originally Posted by INDYMAC,May 25 2006, 06:57 AM
Have you checked your alignment (thrust angle)?
http://www.tirerack.com/tires/tirete...e.jsp?techid=4
i was reading about the trust angle, the way its driving that could possibly it.
BUT, the dealership has done an alignment on the car. wouldnt they have caught this problem while on the anlignment rack?
Old 05-25-2006, 10:29 AM
Project22a's Avatar
Then it could be Radial Pull. Have them dismount your tires and switch sides; see if it changes anything.
Old 05-25-2006, 12:42 PM
or, check the tire pressures first and get back to us, rather than continuing to guess
Old 05-25-2006, 01:54 PM
mic_crispy's Avatar
[QUOTE=BlownAP,May 25 2006, 01:23 PM] on a side note i might have forgot to mention,
Old 05-25-2006, 02:54 PM
us2bwrx's Avatar
i agree with wisconsin's tire pressure remark, the same exact thing happend to me, on every shift it would weave the car slightly, then also i noticed it more when turning, it would be mushy one way and stiff the other way...
Old 05-25-2006, 04:23 PM
9kFever's Avatar
Originally Posted by mic_crispy,May 25 2006, 01:54 PM
did you rev match?
hes upshifting....taking it to redline, ive driven his car and it feels very unstable
Old 05-25-2006, 05:30 PM
loophole35's Avatar
common problem with any dealer or independent shop is they live by the rule set the toe and let it go. Now i'm not saying thats what they did but thrust angle (basicly wheather your car goes strait or "crab walks" down the road) or rear camber could cause the problem but deffinatly check the tire pressure first.
Quick Reply: LSD?
