Lowering your car and driveshaft damage?
Originally Posted by BELGIUMPAUL,Oct 20 2005, 11:21 PM
the biggest problem you could have is to run the car too high off the ground and then flex the cv joints too far
yeah, not to be against the spacers or anything but after doing the math with a friend of mine and a protractor as well as some laser equipment to judge the change of angle, the difference in lenght of my half shafts was 2mm @ 2.1 drop.
not enuff for me to be concerned.. but those w/ added HP and drive harder i would suggest the 7.5mm that the Groupbuy is doing. the 10mm j's seem way too wide and might cause damage from going too much. aso if your not dropped on a true triple perch coilover id suggest even more. i have tein flex w/ minimal susp travel as well as it stays preloaded when off ground so change in angle is VERY minimal. more suspension travel causes more change of angle=more stress.
riley
riley
Good information here. My friend's RSXS has lost two CV's due to his 2.5 inch drop in 30k miles, and I was curious on the effects of a substantial drop on the s2k's suspension geometry with the rwd format. Not that the S needs much more than an inch or two drop anyhow.
yeah my old Es1 civic (same body as rsx) had messed up front axles.. but most of which was from stretching/compressing from turning+drop.
i had the axles rebuilt twice on civic.
1 Post
Originally Posted by Moemers,Oct 19 2005, 11:02 PM
So i've been reading a lot that says if you lower you car, you stretch your driveshaft and apparently, that's not that great. Is this true? Should i get driveshaft spacers to help prevent this problem?
Install took me and my friend 2 hours on the jack. Now I don't feel any shaking at all and have a smile on my face
Well worth the money and time to install
after measuring i feel safe, but worst case i can be like the slovakian pimp in dubai and add em in later and feel great.
then again prolly the camber+drop+harshness on the axles due to autox in your case.. but ill see.
jimmied
07-22-2005 07:17 AM
