lowering springs install
Originally Posted by mattfeet,Aug 1 2008, 10:25 AM
Yes to get stock springs off. If youre doing coilovers, no...since youll be replacing the whole shock/spring unit.
-Matt
-Matt
Originally Posted by CRXsir29,Aug 1 2008, 10:39 AM
thank u! i was able to get away with changing stock springs out in other cars was hoping i could do the same with the S
Originally Posted by StocktonCA,Aug 1 2008, 01:28 PM
How did you do that?
On most coilover sets you will need to recycle the top hats, so you would need a spring compressor.
No biggie though, they are cheap and easy.
I did it without compressors. I just took a t-shirt and wound it tightly around the spring getting as tight as possible. It didn't "pop" all that much. I would suggest a compressor for safetly but if you know what you're doing, they aren't required like in other cars...
dsthez
03-11-2013 12:02 PM
