Lower Control Arm Problems
Old 08-25-2007, 10:47 PM
RACER's Avatar
You could make your own punch from a bolt. Find a bolt that has the same diameter, or slightly smaller as the bolt your removing, then punch the mofo out.
Old 08-25-2007, 10:48 PM
RACER's Avatar
Originally Posted by SoCalIsMyLife,Aug 25 2007, 11:13 PM
I could always polish the rust off. just trying to save some money...
Not a good idea to reuse these bolts.
Old 08-25-2007, 11:00 PM
SoCalIsMyLife's Avatar
punch it w/ what, a hammer or a tool designed for it? Not too much room to swing down there since I have it up on jackstands. I've already used both a hammer and an air hammer.
Old 08-26-2007, 05:53 AM
negcamber's Avatar
Did you squirt them with PB Blaster...some oil to penetrate the rust? Might help it slide out.
Not sure if there is room...but might be able to attach a slide hammer to the bolt to get it to come out.
Old 08-26-2007, 06:33 AM
RACER's Avatar
Yes.
Old 08-26-2007, 07:46 AM
well there's no point of hammering a punch if hammering the bolt doesn't even work
Old 08-26-2007, 03:08 PM
heresnowhy's Avatar
One word: Torch
Old 08-26-2007, 03:54 PM
i'll try some propane i guess. i'm just worried about the brake lines and the steering rack, since I've never used propane before. Any tips on how to best use the propane?
Old 08-26-2007, 04:42 PM
RACER's Avatar
The punch is for when the end of the bolt is flush with the bushing. Apparently, you haven't got the bolt that far through.
Old 08-26-2007, 04:46 PM
RACER's Avatar
Use a bigger, heavier hammer.
Quick Reply: Lower Control Arm Problems
