Low Weight Cat back exhaust
#31
Originally posted by Mike Schuster
Elistan, cutting before the Y split. I may try this. Are there any downsides? Any loss of power?
#32
Is there anyone who has a database on which exhaust adds what amount of HP & torque to the car?
I talked a lot with Comptech when they were designing theirs (I actually had their first exhaust - they installed it on my '00 about 15 minutes before they installed the one for their car!) and it took them many dyno runs and 6+ months to design an exhaust that didn't lose power - they could get HP increases at the expense of torque, or more torque at the expense of HP - the design they went with only ended up with about 3hp at the wheels increase, with no loss of torque - it was the best they could get.
I know there are a lot of lighter options out there, but I'm not sure how many have verifiable (dyno'd) power increases. Anyone know?
#33
Oops - forgot to actually provide the link!
https://www.s2ki.com/forums/showthread.php?...&threadid=73976
Annie - I don't think anybody's put together such a list. The dyno days we've had here in Dallas included exhausts from Mugen, J's Racing, RM Racing, stock, stock w/o mufflers, and single outlet Amuse See the above link. Not a single setup had significant enough differences for me to conclude any specific gains/losses because of the exhaust. So my advise about exhausts is to get as light as possible, without sacraficing your hearing and wallet. If you have the money, that means dual outlet Amuse. If you don't care about noise, J's Racing. If you're on a budget, cut the stock exhaust.
I'd recommend going with designs like the Comptech and HKS only if you're interested in cosmetic (visual and aural) changes. They don't provide enough other benefits to justify the money, IMO.
#36
Just got my stock exhaust chopped before the Y split today, then installed a mandrel bent pipe fitted with a Magnaflow muffler. And since I've already done a baseline dyno two months ago, I will know if I gain or lose any ponies at the same dyno shop next Sat. I'll report back.
#37
[QUOTE]Originally posted by spider
[B]Just got my stock exhaust chopped before the Y split today, then installed a mandrel bent pipe fitted with a Magnaflow muffler.
#38
[B]And since I've already done a baseline dyno two months ago, I will know if I gain or lose any ponies at the same dyno shop next Sat.
#40
That simply isn't true. If you hold your testing conditions constant and use the same dyno, you get terrific repeatability. The keys are:
1. Hold coolant temp to the same levels
2. Ensure that you haven't changed the brand or type of oil you've used
3. Always look at corrected power numbers
4. On roller dynos, ensure that you use the same wheel/tire combo inflated to the same pressure each time.
If you do these things, you should be able to achieve repeatability to within 1% or better. On my S2000, I've dyno'd on 4 different days (on the same dyno) and gotten results within +/- 1hp. The dyno I use (dynapack) is only guaranteed to 0.3% repeatability (or about 0.75 hp on my car), so that's pretty much within the error range of the dyno.
UL
[QUOTE]Originally posted by HondaGuy
[B]
It wouldn't be a legitimate comparison.
UL
[B]
