low rpm at idle
Old 10-26-2014, 08:05 AM
Chance S2K's Avatar
Originally Posted by 00derek
OK, it worked like a charm. Thank you.
Please help me understand why
Why?
Billman is a freaking wizard, that's why
Old 10-26-2014, 08:45 AM
00derek
Guest
Posts: n/a
Originally Posted by MR.T
OP, also curious if this solved your low idle problem?? I know you got rid if the code, but how's your car running?
MR. T, the P0122 was cleared when I installed the new TPS for the first time, but the idle was rough even before then. The idle speed got worse after the TPS was set up to 0.45V (following the instructions that came with the part from Omnipower, which appear to be wrong). Now, after following Billman's suggestion to set the TPS to 6% (4.5V * 0.06 = 0.27V) the idle is correct; slight increase in RPM, not a decrease, when AC is turned on.
Chance S2K, there is no such thing as magic. There is an electro-mechanical explanation and I would like to know what it is.
Old 10-26-2014, 09:51 AM
MR.T's Avatar
this kind of makes me wonder if the tps is the root cause of a lot of idle problems.???
Old 10-26-2014, 05:07 PM
windhund116's Avatar
Received 1,529 Likes on 1,033 Posts
Originally Posted by Chance S2K
Why?
Like to think it isn't wizardry or black magic... but hard earned experience. Works for mechanics and surgeons.
Zygrene
05-11-2016 05:05 PM
ousi
13
10-05-2011 07:38 AM
SNH
05-30-2011 11:47 AM
AP2_s2000
07-11-2010 09:59 PM
Quick Reply: low rpm at idle
