low rpm at idle
Old 10-24-2014, 09:03 PM
00derek
Guest
Posts: n/a
Default low rpm at idle
AP1 S2000 with 80,000 miles
Warm engine, idle is 800-900 rpm.
When I turn on AC, idle drops to 500 rpm and engine feels like it's about to stall. Service manual says idle speed should increase from 750-850 to 850-950 with an added load like AC.
I recently installed an adjustable throttle position sensor from Omnipower to clear a CEL, and it worked; CEL is gone, but the idle problem seems to have gotten worse.
I've read the posts and done the following;
replaced air filter (stock --> stock)
cleaned throttle body and ports to IACV and MAP, new TB gasket of course
cleaned IACV - not spotlessly clean but it moves freely
replaced MAP and o-ring
cleared ECU and performed idle learn procedure
drove it for a week with no improvement
no CEL at present
Your suggestions would be most welcome as my next stop is the mechanic
Old 10-25-2014, 04:51 AM
franky's Avatar
What was the cel before u installed the adjustable tps?
Old 10-25-2014, 06:09 AM
00derek
Guest
Posts: n/a
P0122 - Throttle Position (TP) Sensor Circuit Low Input
voltage was 0.3V with the old sensor - should have no effect on the idle as the throttle is fully closed.
0.45v with the new sensor. also installed a new gasket under the sensor.
Old 10-25-2014, 01:27 PM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Tune the tps % to 6.
Old 10-25-2014, 02:49 PM
00derek
Guest
Posts: n/a
mmm
I'll give it a try but can you explain why?
6% is 0.27V; that's lower than what the old TPS was reading (0.3V) at idle when I had P0122
Instructions from Omnipower say set the TPS to give 0.45V at idle.
what gives?
Old 10-25-2014, 04:50 PM
00derek
Guest
Posts: n/a
OK, it worked like a charm. Thank you.
Please help me understand why
Old 10-25-2014, 09:26 PM
superchargedk20's Avatar
I've seen through many threads not to question billman. Just do what he says
Old 10-26-2014, 06:23 AM
00derek
Guest
Posts: n/a
I just want to learn something so maybe I can help the next person.
Old 10-26-2014, 07:17 AM
MR.T's Avatar
I'm interested in this too. I too have idle problems and not long ago got a P0122. Cleared it and it hasn't come back since. The tps stickie was on my list if to-do's
Old 10-26-2014, 07:30 AM
MR.T's Avatar
OP, also curious if this solved your low idle problem?? I know you got rid if the code, but how's your car running?
Quick Reply: low rpm at idle
