Low oil, it is normal right?
Old 10-28-2009, 08:57 AM
Fredster's Avatar
ap1's are known to burn oil, if i may suggest using a different oil, our cars adapt to different oil weights at times.
Old 10-28-2009, 09:45 AM
Ralleh's Avatar
I haven't had this car for too long, but it's a million times better with oil than my BB6. Still check 1-2 times a week though after it has been sitting on flat ground over night.
Old 10-28-2009, 10:12 AM
CarbonS2kEddy's Avatar
i use valv syn n i dont burn oil... check it ever 3 days too...
Old 10-28-2009, 10:18 AM
MurderS2K's Avatar
shitty oil for sure in this beast
Old 10-28-2009, 11:11 AM
Fredster's Avatar
i wouldn't say that quite yet, a lot of ap1's as i've stated before burned oil regardless of the brand.
Old 10-29-2009, 01:19 AM
jyeung528's Avatar
Originally Posted by iDomN8U,Oct 28 2009, 05:29 AM
Do you let your car sit for a while on level ground before you check?
From low to high should only need 1 quart
Also, if your burning 1 quart every 1000 miles, you have a issue with your car. Unless those 1000 miles are track miles
1 quart per 1,000 miles is acceptable according to honda.
however, that is the maximum threshold.
i burn about 1 quart per 1,000 miles. my compression and leakdown numbers have been fine.
Old 10-29-2009, 08:42 AM
bakalag's Avatar
Whats a Krank Vent? Can someone provide more info on it please? lol
Old 10-29-2009, 05:37 PM
jyeung528's Avatar
krank vents are similar to your pcv valve, it is a valve that allows air to travel only in one direction and blocks flow for the other direction.
by using this valve in the breather tube (and the pcv tube) it creates a vacuum in the crankcase, thereby reducing the oil that gets past the piston rings and getting consumed in the cylinder.
what i don't like about it is that the vacuum sucks on all the seals. i'd rather just top off the oil.
Old 11-08-2009, 12:14 PM
bakalag's Avatar
I got an oil change 400 miles ago where they put 5 qt of oil in the car. I just checked the oil and it's at the 2nd notch at the bottom, is that a normal reading? I've driven about 200-250 miles only on local streets 4-45 mph (occasional stop and go) rest on highway. I haven't hit VTEC since the new oil was put in (love heavy traffic).....yet.
Old 11-08-2009, 12:27 PM
CKit's Avatar
Didn't you check the dipstick reading right after the oil change?
Quick Reply: Low oil, it is normal right?
