Low compression head gasket
I recommend a steel head gasket to drop the compression. Some people have said the copper will not with stand the heat and they compress over time.
AEBS is located in Cali.
[QUOTE]Originally posted by SuzukaS2K
[B]Since the block is out now........do you all think that if I sleeved and o-ringed the block and put in lower compression piston, rods etc......will it work without any head work done while having the boost level turn up couple psi?
chrisD how much you boosting? another question for everyone else, when you lower the compression on the car doesn't it lower the performance of it as well? A Newbie question i know but was just wondering. Thanks guys
What terry said. The amount of horsepower you'll gain by adding boost will far offset the amount of horsepower you'll lose by lowering compression. Generally those concerned with increasing compression are those who are trying to get more horsepower out of a NA application.
I'm currently boosting about 4psi, because I don't have my wastegate spring and boost solenoid installed, amongst other non-car related problems (my laptop battery died, it makes programming the EMS difficult). I expect that after this week or two I'll be boosting 22-25 psi.
[QUOTE]Originally posted by evo s2000
[B]Jackie
The block I recommend you rather do a Mike Simmon set up. Full block and head. Or give the block to AEBS. They are very good, they have done a few s2000 block already.
[B]Jackie
[QUOTE]Originally posted by Andrew Doherty
[B]I think the gasket you are reffering to is the copper style!?!?!?!
anyway if it is I would talk to CJB80 (chris) he had major problems with the copper gasket.
Also as far as I understand when you lower the compression ratio with the head gasket and not the pistons you increase the risk of detonation & knock in your engine, this could be compleate crap but I think its right
