low compression cyl #3
Old 06-10-2007, 06:11 PM
dhayner's Avatar
[QUOTE=ericg,Jun 9 2007, 09:57 AM]....
I agree symptoms may be pointing to head damage (BTW in this case AP2).
Old 06-10-2007, 10:35 PM
jyeung528's Avatar
i have an ap1...
i don't think ap2 is different, but i could be wrong...
isn't 250 a bit HIGH for our cars?
Old 06-10-2007, 11:05 PM
iam7head's Avatar
Originally Posted by jyeung528,Jun 10 2007, 10:35 PM
i have an ap1...
the thing is, no one seem to agree to use how many pull/crank, most people will just post the highest compression vs. average number from mutliple test.
the condition, brand of gauge and battery condition also played a role here.
i do 9 cranks and at least 3 times for each cylinder, i gotten a 215 on a brand new 07 so i know my gauge reads on the low side.(plus sh-t load of other cars)
there's people that does 15 crank pull(and killing half of the battery ) just to hope for a higher number.
Old 06-10-2007, 11:07 PM
iam7head's Avatar
Originally Posted by dhayner,Jun 10 2007, 06:11 PM
The compression going up to equal with the other cylinders when you put oil in indicates rings, not head.
yep, you are right.
the idea of wet test is to use oil as a temp. seal for the piston ring(the oil goes to the ring by gavity and hopefully the rings have enough seal to hold the oil for a quick crank)
by doing so you are pin pointing the problematic area.
Old 06-11-2007, 05:30 AM
mxt_77's Avatar
No. Depending on the gauge, that's about right. I get about 245-255 on my Craftsman gauge. I've noticed ambient air temps also affect it. Warmer temps = lower reading.
Old 06-22-2007, 05:42 AM
andrewboro's Avatar
I am going through the same thing with my car. Its an AP1 with 74k miles, CEL comes on and goes off. Idles fine, oil temps are fine, power is fine, mpg is normal. Took it in yesterday and the dealership told me they had pulled codes for cylinder misfires. They found low compression in Cyl#2 and are telling me I need to replace all the valves and have the piston heads reshaped. I plan on getting a second opinion.
At a cost of $3,000 why isn't this covered under my 100k mile warranty?
Old 06-22-2007, 08:17 AM
a3lkx's Avatar
interesting
Old 06-22-2007, 10:05 AM
Master S2K's Avatar
your head leaking oil anywhere? start looking around it. Ever had your head removed?
Old 06-22-2007, 11:37 AM
chino101's Avatar
What was the dealerships answer to this question?
Old 06-22-2007, 12:00 PM
andrewboro's Avatar
They are saying, it was caused by an over rev and I am at fault. I have not over revved the engine, I think I would know if I had.
Quick Reply: low compression cyl #3
