Low Cold Idle Speed
Low Cold Idle Speed
Ok i was just wondering what the problem with my car is. The cold idle speed is around 1000 RPM. What would cause this? Could it be the ECT? btw i have K&N fipk and a 70 mm skunk 2 Throttle body. Could the throttle body be the cause of the low idle speed. Its always been like this since i got the car. In the summer and this is my first winter with the car and im pretty sure that the idle speed should be around 2000RPM.
yeah at start up it may idle at the two grand mark for a minute but it does usually drop to 1000 idle. throttle cable could be too tight also (if consistently idling high), previous owner may have tightened the slack for improved throttle response...
