Lousy Honda - thermostat fails at 148k
Old 07-13-2005, 07:29 PM
modifry's Avatar
Default Lousy Honda - thermostat fails at 148k
OK, just kidding, this kind of thing should be expected at my mileage. The interesting part is that I wouldn't have found the failure until possibly experiencing a real 'breakdown' if I didn't have a 'modifried' temp gauge. During my 'overheating' experience the temp never hit 235 - the point at which a stock gauge indicates 4 bars. I only knew it was abnormal because of the gauge modification.
I've been running my ECT module* for 7 months and know exactly how the gauge works - 3 bars in cool weather, jumps to 4 bars with extended idling, then back to 3. Hot weather brings more 4-bar time, even see 4 bars at steady 40mph if ambient temp is over 90
Old 07-13-2005, 07:36 PM
cdelena's Avatar
[QUOTE=modifry,Jul 13 2005, 09:29 PM] A stock gauge reads 3 bars between 160
Old 07-13-2005, 07:53 PM
modifry's Avatar
I would love to see factory specs, I'm going by what the OBD says.
Old 07-13-2005, 09:53 PM
AusS2000's Avatar
Old 07-14-2005, 06:25 AM
cdelena's Avatar
Exactly where I got he first few numbers.. I correlated OBD numbers with the gauge on my car (and just projected to get the 6 - 7 bar estimates). I am thinking the pieces are not high precision and that my Hondata gasket may make my numbers a little different.. although they are logical if you look at thermostat and fan specs.
Old 07-14-2005, 10:48 AM
Tyler N's Avatar
148k miles? damn, I love hearing that. As been stated by many, it's nice to know the S seems to be just as reliable as you would expect from a Honda even with the high strung engine. Keep up the good work man and be safe at the track!!
Tyler
Old 07-14-2005, 11:48 AM
TR-S2K's Avatar
148k miles only ? Honda thermostat should last the life of the car or 500k miles whichever comes last. Honda owners should only fill-up gas tank when needed and may be oil change every 50k miles or so, no other maintenance is needed. j/k
Old 07-14-2005, 01:10 PM
vAnt's Avatar
When should I expect my car to jump to 4 bars?
I've NEVER seen it happen ever. I'm at around 16k miles...
Old 07-14-2005, 01:50 PM
mikegarrison's Avatar
With a stock ECU, if you ever see 4 bars it probably means your engine is already ruined. What appears to be a useful gauge is really just an "oh shit" light.
Old 07-15-2005, 06:15 AM
The Hoth's Avatar
How often our S has to replace coolant anyway? Every 30,000 miles?
Quick Reply: Lousy Honda - thermostat fails at 148k
