A loud banging noise when engaging to 1st gear and excessive grinding on 1st thru 4th gear.
A loud banging noise when engaging to 1st gear and excessive grinding on 1st thru 4th gear. I had a stage 2 competition clutch install about 4 months ago.
So I think best thing to do is talk a look at it. Any unusual amount of clutch dust, smell? Mileage? Driving it normal or spirited?
Checked your clutch resevoir? Make sure it's topped off. I'd go ahead and replace the fluid while you're at it. It's quick and easy and you can check the slave while you're down there.
