lost sixth gear
Old 05-06-2007, 10:01 AM
dmantee's Avatar
Originally Posted by dorfnation,May 6 2007, 10:46 AM
ok thanks guys, looks like i'm buyin a low mileage tranny
Had a similar problem with 5th in my old civic (b-series). 5th wouldn't go in and the car began making a unique noise, sounded sorta like a whining throwout bearing. Was driving it around the block and boom, no more tranny - broke a shift fork and it locked 1st and 3rd gears together if I recall. Get it fixed before it goes completely.
Old 05-06-2007, 05:00 PM
RACER's Avatar
Originally Posted by dmantee,May 6 2007, 11:01 AM
no more tranny
Old 05-06-2007, 07:02 PM
cdelena's Avatar
As mentioned before, there is a good chance it can be forced. A number of failures have been resolved that way... here is my post from the past:
Originally Posted by cdelena,Aug 30 2004, 09:44 AM
OK.. every chance I had to shift to sixth I took as an opportunity to force the shifter. Finally after about twenty tries I got the whole gear box to jam.. no shifting at all, but was able to work it loose. I now have all six gears but 5 and 6 are very stiff and hard to use. I am hoping it will loosen up with use. Thanks for the responses.
After regular use and a lube change it is back to normal since.
Old 05-07-2007, 02:05 AM
WhiteAP1's Avatar
I had a similar problem a while back. I forced it as instructed, and i havent had any problems since. Plenty of spirited drving and track time and its fine. IMO a replacement gearbox is overkill.
Old 05-07-2007, 04:08 AM
S1999+1's Avatar
I would try the force into gear before shelling out teh $$ on a good used one. If you're going to replace it anyway, why not try that first. Even if it's only a temporary fix, if it gives you 6 more months on that tranny, it's worth it and if you're replacing it anyway, it's not going to get any worse.
Old 05-07-2007, 08:32 AM
Blitzkrieg's Avatar
I might try putting more pressure on mine tonight, it's worth a shot. I met with the appraiser today, tomorrow I'll find out if USAA will pay for a rebuild.
Old 05-07-2007, 09:40 AM
Blitzkrieg's Avatar
Add me to the list of people who "fixed" their own transmissions. I was surprised that it worked. It just needed a little more force than I used before and now it works fine again :-D
trump26901
09-02-2007 11:44 AM
98TypeR#21
02-24-2007 04:27 PM
Kane_X3
03-18-2005 09:35 AM
RU2KREDY
08-30-2002 06:00 AM
crusty
06-05-2002 05:53 PM
Quick Reply: lost sixth gear
