Loss of power! Please help!
Old 02-18-2005, 12:15 PM
  #191
Mighty's Avatar
Hmm...
I think you said you checked your grounds already but Id like to say that I had weird loss of power problem with my Civic after I converted it to OBD 1 and didn't ground everything properly.
You also said the car is running rich when this is happening? Do you think you could get your hands on a wide band O2 sensor to check what your AFRs really are when this happens.
Are there any dynos in your area? Perhaps you could use them to help troubleshoot?
Also I would be interested in what your vacuum and fuel pressures are?
I know that you said your mechanic checked them but Id still like to know the numbers. When you said it was running rich I was thinking maybe your fuel pressure regulator is failing closed occasionally causing high fuel pressure and causing you to run very rich.
Old 02-18-2005, 12:17 PM
  #192
Promeds's Avatar
Hope things get better for you, good luck!
Asghar.
Old 02-18-2005, 12:32 PM
  #193
jyeung528's Avatar
let us know if you can fix it
Old 02-19-2005, 03:54 AM
  #194
NorthCyprus's Avatar
I'll definetly let you know, the main problem is the country i live, you cant find any proper mechanics , just a few and even them counldnt find the problem, main Honda dealer here? said there's no problem with the car! I'll be trying and i'll let you guys know.
Old 02-19-2005, 07:43 AM
  #195
I went to my mechanic today, and he said i maybe need new injectors, what do you guys think of that?
anyone had injector problems before?
similar with mine?
what cc are the standard injectors for s2k?
does it differ in US - EU - JP ? coz my car is a japanese version but i live in middle east!
Old 02-19-2005, 09:45 AM
  #196
xviper's Avatar
I've not heard enough incidents of bad injectors on this car to say that it is a "problem" area. Before you go spenting big money on new injectors, can you get them taken out, cleaned and flow tested? If you have such a facility, this might be cheaper than getting new ones. If they test out to be fine, then you still something else to track down.
Old 02-19-2005, 11:34 PM
  #197
Warren J. Dew's Avatar
Originally Posted by NorthCyprus' date='Feb 18 2005, 11:07 AM
What i did about the fuel system was:
-Using best quality fuel (100 EU octanes : 98 US Octanes)
Higher octane will not help the injectors stay clean; it will only help with an engine that has cylinder deposits increasing the compression ratio.
To help the injectors stay clean, you need a fuel with sufficient detergent in it. In the U.S., I believe all gasoline has certain minimum levels of detergent, and some (e.g. Mobil) have much higher levels. I don't know the specifics for Cyprus (or wherever you are located), though.
Old 02-19-2005, 11:56 PM
  #198
mugens2003's Avatar
it's your catalytic coverter... son go check it out been there had that problem
Old 02-22-2005, 07:41 AM
  #199
I did change the catalytic convertor before, didnt sort the problem out.
I did the ultrasonic injector cleaning before, as i mentioned, and i did have the injectors tested, my mech said there was a blockage in the injector no 4 but he did clean it, than checked it again, it was ok (he said). The thing is, after cleaning the injectors again, the car seemed to be fine for a while. It was better, thats why i think it's related to the fuel system. Any comments about what can it be about the fuel system?
Old 02-22-2005, 08:07 AM
  #200
xviper's Avatar
If it is fuel system, much can be revealed by checking the fuel pressure in the rail.
Quick Reply: Loss of power! Please help!
