Loss power once warmed
Hi all
i have noticed recently my car feel very weak once warmed it takes ages to get to vtec feels like i am pulling another car !!
the first 10min of driving is fine nice and smooth,
already changed new plugs, all fluids cleaned MAP and ICV sensors
NO CEL
please help
NO CEL
please help
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
what intake setup do you have - oem air box, oem air box with lid removed, aftermarket intake ?, if it is any of the two last setups I listed then that would explain your issue. If it is the oem setup then I don't know what else to suggest other than normal heat soak like mentioned above. In high heat conditions the ecu gets more conservative with timing plus high temp air results in lower power. How are your coolant temps ?, normal ?
Thanks for the reply guys
my current set up:
closed Stock air box with Mugen filter
63mm test pipe
if i run a spoon type intake duct with the OE airbox will that help?
the difference in power is night and day, once warmed its really really slow
my current set up:
63mm test pipe
WRCGooseS2K
04-18-2016 01:54 PM
