loose rear axle nut, ? best way to re-tighten
i suspect my "creaking noise is loose rear axle nut, probably left side.
can i just torque up to spec, 181 ft-lb ?
how do you lift the locking tab, just pry it up?
should i remove nut completely and oil spindle and then re-torque?
you can tighten it with wheel on ground??
thanks.....i need to go change my spark plug fluid now!!!
solitarycheese
05-26-2017 11:10 AM
