Loose hose, leaking water? P0497 CEL
Got a loose hose and a CEL light that just happened today. I don't think they're linked to each other but I didn't want to make two separate threads.
CEL code is P0497, help.
Here is the loose hose, help. (Right side of car almost directly under the passengers feet.)
http://i40.tinypic.com/15db5lc.jpg
Thank you in advance
Yes AC drain that hose is normal.
Your code is an evap leak. Careful inspection of all lines/hoses by the charcoal canister is a good place to start.
