Looking for nut for lower portion of shock
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
![](https://www.hondapartsnow.com/diagrams/large/front-shock-absorber-462403.png)
See where the bolt at #16 goes into the stock shock, there's a nut that seems to be welded onto the stock shock itself. I just installed Megan coilovers and actually don't have that nut, and Honda probably doesn't have a part number that fits the s2k for it, since there isn't a separate nut from factory.
What did you guys use? A generic one from home depot, or anything else maybe cross referenced from another car?
Looks like the same issue is for front and rear also.
http://www.meganracing.com/products/produc...id=383&catid=93
- Includes 4 19mm nuts for perfect fitment.
Just noticed, but I got mine fairly new from a local, so no nuts on them.
Take the bolt to a hardware store, and find a Grade 8 nut for it. Maybe grab a lock washer to go along with it if you feel they will back out.
There are also locking nuts (has a flange with cuts in it) if your hardware store is good, they should have those.
Ohh, gotcha, I was thinking of bringing the bolt to Honda to see if they can cross reference any other nuts.
Would using a locking washer seize the nut more in the future?
dulslo666
04-17-2009 06:58 AM
