Looking to buy a ECU Scanner (Plus Trip Guage?)
For those that have their own OBD II scanner, I need your recommendation. I'm not looking to use this commercially, just for my own S2000, so I am not looking to spend a lot but I do want to get useful features if I can.
The Basic Scanner:
http://cgi.ebay.com/ebaymotors/ECU-P...item5198f05e9b
A Scanner and More:
http://cgi.ebay.com/ebaymotors/Turbo...item35af5f4679
Any other suggestions that you find a 'must have' features?
Thanks!
The Basic Scanner:
A Scanner and More:
Thanks!
Torque is awesome. I've got it. Need an Andriod or iPhone. The app is like $5. The bluetooth dongle that plugs into your OBDII port can be a cheap chinese thing for $20 that may not work, or a good one for $70. It's awesome, and does way more than a scanner.
http://torque-bhp.com/wiki/Main_Page
https://market.android.com/details?i...l.torque&hl=en
I have a scangauge II in my Genesis Coupe and an ultragauge in my s2k. The following are my observations of each:
Scangauge II:
intuitive
Change backlight colors to match interior lights
Ability to add gauges
Easy to access, responsive buttons on front of device
no alarms
More expensive ($160)
Ultragauge:
More cumbersome interface
High contrast screen, but you can't change colors
Set alarm thresholds ( for example you can set an alarm to go off if coolant temps reach a certain value)
cheap ($60-70)
Buttons are on back of device and stiff/not very responsive
Either device is well worth the money and allows you to monitor ECU readings, fuel mileage, and read/reset check engine codes
Scangauge II:
intuitive
no alarms
Ultragauge:
cheap ($60-70)
EternalLx
02-12-2009 12:33 PM
