Locked steering wheel in cold weather?
Maybe the connections are loose and the cold made the contacts contract enough to loose power. I know my '01 is hard to turn right in the cold. I'm pulling the rack today and tearing it down for the same reason coincidentally.
Sounds more complex than just cold PS fluid. I've had my PS fluid get really thick in negative and single digit temps, but that makes the EPS light come on and you lose power steering until it warms up, but you can still turn the wheel and drive with a little increased effort.
So here's an update, today was above freezing, I believe 34 degrees-ish.
The steering wheel was just fine, no sticking whatsoever which adds to the freezing theory.
A suggestion was that maybe the tires were stick to the road? I tried rolling the car back and forth a few feet. If the tires were frozen to the road, that should have solved the problem but it did not.
Well anyways I'll update you guys further as news becomes available.
-Ri.Le
-Ri.Le
Here are some other posts made by other owners who all have had a similar problem:
https://www.s2ki.com/forums/index.php?showt...dpost&p=2939087
https://www.s2ki.com/forums/index.php?showt...dpost&p=9964348
https://www.s2ki.com/forums/index.php?showt...post&p=15141589
https://www.s2ki.com/forums/index.php?showt...dpost&p=7134455
https://www.s2ki.com/forums/index.php?showt...post&p=17503164
The commonality I noticed between all these owners was that they all owned AP1's .
-Ri.Le
-Ri.Le
