Locked axle?
Old 11-10-2011, 05:01 PM
BigBang's Avatar
Default Locked axle?
Putting my springs on and now my hub has really bad positive camber and wont move back to normal. Im trying to connect tbe A arm but its not moving. Any ideas?
Old 11-10-2011, 05:04 PM
BigBang's Avatar
Old 11-11-2011, 01:46 AM
Leviisbigred's Avatar
ill bet you pulled it to far and it came apart. feel the boot on the drive ax and try pushing it back it.. if you pull it to far out it will lock up.. you may have to move the hub up and down for it to go back in.. oh and its on the Diff side of it
Old 11-11-2011, 07:09 AM
BigBang's Avatar
Ive been moving it up and down with no luck.. You mean move the boot for the drivers side axle around?
Old 11-11-2011, 09:11 PM
2003AP1's Avatar
Did you pull the axle out on the other end by accident?
Old 11-13-2011, 02:03 AM
try spining it
Old 11-14-2011, 08:38 AM
SilverS2kF22C1's Avatar
Sounds like the axle came out. If you do the install again you don't need to disconnect the upper A-arm on the back. just disconnect the sway bar from the body and push down. on the axle there is enough room to pull out/install the shock/spring assembly.
Old 11-14-2011, 10:00 AM
Banned
vividracing.com's Avatar
Yep, sounds like your axle came out. Try spinning/wiggling/pushing/magic. Usually it helps to have another person push the axle until it stops and hold it there. Then you can feel around on the rubber boot and get an idea of how to maneuver it in order to get it in the hole.
Old 11-14-2011, 10:04 PM
Originally Posted by vividracing.com
Y Try spinning/wiggling/pushing/magic. Usually it helps to have another person push and get an idea of how to maneuver it in order to get it in the hole.
thats what she said lol
sorry i had to
Old 11-15-2011, 05:42 AM
hypforlife32's Avatar
Good one ^^
Quick Reply: Locked axle?
