location of wideband o2 sensor
Hey gang. Has anybody permanently installed a wideband o2 sensor with the stock header? Can you simply swap out the stock o2 sensor and put the wideband in its place or do you need to install it in a different location? If not in the stock location what would be the best location?
Bad idea to install in the header -- too hot and too close to the engine. Use the front O2 sensor bung if you don't need your front O2 sensor (i.e., you have an EMS). If you do need your front O2 sensor, have a bung welded near the same location and (this is important) at a slightly downward angle to protect against condensation (just use the angle of the stock bung as a guide).
__________________
C. Bender
2001 S2K Silver/Black
AEM EMS, Fuel Pressure Regulator, and Wideband O2 Sensor; RC Engineering 550 Injectors; Turbonetics TO4B 60:1 Ball Bearing Turbo; Tial 46mm Wastegate and 50mm Blowoff Valve; GReddy EGT and Boost Warning Gauges; Upgraded Intake Fuel Pump; Oil Filter Relocation Kit with Stainless Steel Lines; Speedcraft Front Mounted Intercooler, Mandrel Bent Tubing, 3" Down Pipe, and 3" Stainless Exhaust; A'PEXi N1 Mufflers; Clutchmaster Stage 3 Clutch; Toda Lightweight Flywheel; Mugen Radiator Cap, Thermostat, and Fan Switch; Upgraded Oil Bolts; Spoon X-Brace; HeCash Brake Ducting; Competch Stainless Steel Brake Lines; WorkMeister S2R 18" Wheels; Lucid's Front and Rear Speakers; 2002 Stereo Head Unit; Rick's Front Badge; JDM Clear Side Markers; Muz Shift Knob; Uber Cool Nurburgring Decal
__________________
C. Bender
Vortexhunter (08-29-2019)
Sometimes we're all 12 at heart....
1st one is in the downpipe? Isn't the first one about 12" in front of the cat? and the second one in the cat?
That would make the first one be in the header, no?
well, considering it's all one piece, most people just call it a header, and yes the first sensor goes in it.
shall we continue to split hairs and confuse more people than we help?
PS: I need T.P. for my bunghole!!!!
Sorry about the confusion -- I hadn't realized the stock piece extended so far. I ditched it when I had the turbo installed, and I just assumed that it turned downward and then bolted to a downpipe. But, yes, that's where the bung ought to be, and even I'll go buy some toilet paper...
CB
CB
so the verdict is another bung hole (so punny every time) near the first o2 sensor? i am going to be using the stock header and computer for now but will have a vortech. i want to be able to continually monitor a/f ratios via wideband o2.
okay, that makes sense, seems like my turbo-sense was tingling
yeah, you have two options for the sensor, in the cat and before the cat (header, down-pipe, crack pipe whatever ) I would think you want the wideband in the header, in front of the cat. I will be putting a wideband in the header pictured above, running an ems, and not using a second o2 sensor, unless I can figure out a benefit to using it
