limp clutch and clutch engades differently
Master cylinder or slave? or both? For the master cylinder, buy a generic cotter pin that fits, you're going to hate Honda Engineering when you attempt to remove the OEM one. Just rip it out with needle nose pliers and replace it with the generic. The other stuff is pretty self explanatory.
I had the exact same symptoms a few months ago. My clutch master cylinder was empty. Without any help, here's what I did:
I have checked my clutch fluid level periodically, and it hasn't gone down at all. I guess that over 8 years it very gradually seeped out. I see no drips anywhere. I'm not going to replace anything until it drains the master cylinder faster than at least once a year.
- Jack up the car and attach a plastic tube (1/8" clear tube from the hardware store, IIRC) to the slave cylinder bleeder valve
- place the other end of the tube in a small cup or bottle
- fill the master cylinder with DOT 3 or 4 fluid
- Have someone press the clutch pedal to the floor. If alone, wedge a stick or something between the seat and clutch pedal to hold it down. I used a 2X4.
- Open the slave bleeder valve then close it when fluid stops flowing
- lift up the clutch pedal then press and hold it back down again
- Repeat step 5 and 6 around a dozen times, topping off the master cylinder when it gets low.
