limited slip differential
Old 02-03-2004, 04:09 PM
gerryk's Avatar
Default limited slip differential
Do our S2ks have LSD?
Old 02-03-2004, 04:19 PM
jerrypeterson's Avatar
Yes, the S2000 comes from the factory with a Torsen differential.
Old 02-03-2004, 07:00 PM
s2000turbo's Avatar
Yes, but some people change it
Old 02-05-2004, 10:48 AM
R6Brian's Avatar
So, if I understand what you're trying to say. my 2001 has a limited slip diff? I got stuck in the snow the other day and only my right rear was spinning because it was in the snow and the left rear was on the pavement and wasn't moving. What gives?
Old 02-05-2004, 11:17 AM
Big Ben's Avatar
Torsen is a viscous diff If I'm not mistaken. The viscous will only work with substantial wheel speed.
Old 02-05-2004, 12:01 PM
fuse's Avatar
You can read it from here...
http://www.torsen.com/general/general_faq.htm
I think Torsen is a helical design, if one wheel is spinning freely, it doesn't work...quote from above link...
"As mentioned above, the Torsen differential is a torque multiplier. The Torsen requires some type of resistance or friction in the system to function properly. A wheel in the air provides zero torque or friction on the system and as the Torsen multiplies the available torque, zero, by its TBR, the end result is still zero. In response to this, we developed the Torsen T-2R with pre-load to combat those wheel in the air situations. "
...spinning 1 rear wheel in the snow is pretty much same as 1 wheel up in the air.
Old 02-05-2004, 12:11 PM
vapors2k's Avatar
[QUOTE]Originally posted by fuse
Old 02-05-2004, 06:43 PM
BozzSpeed S's Avatar
Upgrade to a 1.5 or 2way LSD like Cusco or others. Because you'll find Torsen is the weakest link in the S2ks...not my opinion though, just something I learned from a japanese tuner.
Old 02-05-2004, 07:15 PM
Lycean's Avatar
Apparently you can gently apply the brakes to create some drag on the spinning wheel which will transfer some of the torque to the non-spinning wheel.
Old 02-07-2004, 07:44 AM
l8brakr's Avatar
[QUOTE]Originally posted by Lycean
Quick Reply: limited slip differential
