Lets talk jacks/lifts.
#41
Yes, you lose side access, but two pairs of jackstands can also be a challenge to navigate around.
The 20" lift height allows me to comfortably access anywhere under the car on a creeper. You just have to enter from the front or the rear of the car.
At the end of the day it's a lot of money to spend, but that is the only negative. Don't try to talk yourself out of it because of any loss of access, setup time, storage limits, etc. If you can afford it, get it. It's safer and simple to use. I work on my two teenager's cars as well as the S2000 so it was easily worth it to me.
#42
#43
Yeah, as I said I have a line on one for $1000 I'm going to go see tomorrow. I'm thinking the QJ would be a good addition to my garage which would let me work on my pickup and the wifes Charger as well. They list the weight of my 2010 dodge ram 1500 at 4500-5500 pounds, I'm hoping it will still pick it up! It says 5000 pounds but I think there is a little leeway there... the Charger is 3900 -4400 pounds.
Quickjack sells an extension that can add about 6" to the length which may be enough.
#44
I think a lift is essential for DIY maintenance on a car even my "just fluids" type preventive maintenance. Despite appearances I don't get a commission from EZcarlift. There's little difference between safe and safer. And our perceptions. I ain't going under a car on jack stands if I don't have to for example. Glad you're not going under either.
-- Chuck
-- Chuck
Second question, will it work on a slope? I guess its similar question for quickjacks. Driveway has significant slope.
#46
I've been using it for years. Short of pulling the transmission out, I can't think of any job you're likely to do that it would get in the way of. I've dismantled the entire suspension, replaced clutch slave, master, and line, removed exhaust, prop shaft, differential, replaced drivetrain bushings, etc.
#47
Will it work in a driveway?
Question best answered on the EZcarlift website. Like I wrote, I don't get a commission.
-- Chuck
-- Chuck
#48
Another vote here for the quickjacks. I’ve used them for 3 of my vehicles (s, ford escape, keep compass), haven’t tried my 1500 Silverado yet. I got the 7000lbs version so I can use it for the truck though. Haven’t run into anything I’ve had an issue with yet. Easy to set up and tear down,even if they can be a little heavy moving around after you work on a car for 6 hours.
A.O. (12-02-2022)
#49
So like I've said, I'm going to go look at a used set tomorrow... is there anything I should be wary of.. something that is a cause for concern?
#50
So those of you that know me know I'm not afraid to travel for stuff and yesterday was no exception. Located a used Quickjack just north of Atlanta which is almost 5 hours away, road trip time! We headed out about 8;30 and got home about 7:30 so it was an all day adventure. But I got an almost new BL-5000SLX from a guy who says he only used it one time and it looks that way, still shiny even the hydraulic hoses are still shiny, all the fittings looked like brand new and all have their protective caps. $1000 for all so I'm thinking I did pretty good! The guy even threw in a brand new creeper and a couple large drip pans!
The following 4 users liked this post by A.O.:
